Denon 3803 Help - baby has changed something and don't know what to do
Discussion in 'AV Receivers & Amplifiers' started by lawrenso, Jan 12, 2004.
Tags:
  1. lawrenso
    lawrenso
    Oct 6, 2003
    1,185
    48
    Flintshire
    +35
    On my 3803 - I can not go above -2db on the TV input - I can only think that my 7 month old has had his hands on it or the remote and done something.
    Can somebody please tell me how to remove this
    Many thanks
    Steve
  2. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    You could try a system reset.
  3. S H A D O
    S H A D O
    Mar 16, 2001
    10,436
    United Kingdom
    +1,818
    Doublecheck the Channel Levels for that mode/input. Sounds like they've been tinkered with!
  4. lawrenso
    lawrenso
    Oct 6, 2003
    1,185
    48
    Flintshire
    +35
    After a bit more investigation, this happens for DPL II and DTS Neo on all sources. For some reason it won't go above -2DB, however if I switch to Stereo it will.
    I think I will have to give a call to Denon to sort this out unless somebody has any more ideas
  5. S H A D O
    S H A D O
    Mar 16, 2001
    10,436
    United Kingdom
    +1,818
    Did you check the Channel Level settings for that mode? The Denon stores them independantly for each mode although it lumps Dolby PL2/DTS Neo/Dolby/DTS together as one. Pressing the STATUS button on the front panel will cycle through all the settings for the current mode and input. Just cycle through until FL, C, FR etc appear, then compare them to what it has set for Stereo etc.:) If that still doesn't solve the problem then try a Processor Reset but you'll need to re-input all your settings (Delay Distances, Speaker Setup, Digital In Assignments etc) as they are reset to the Defaults. Write all yours down beforehand and then just key them back in again after you've reset the amp. :)
  6. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Yes, it does sound like tampered channel level settings. You've probably got all channels set to +12dB or similar.
    Otherwise you're buggerred, as my 1803 will go up to +12dB in PLII & Neo 6.
