Denon 3803 Bi-amping
Discussion in 'AV Receivers & Amplifiers' started by Dave777, Aug 8, 2003.
Tags:
  1. Dave777
    Dave777
    Oct 25, 2002
    480
    Gatwick
    +8
    Can anyone confirm if the Denon 3803 can be bi-amped. i.e. I want to use the 7 channels to be a 5 channel amp with the front pair bi-amped. I lnow the Pioneer 2011 can do this but can anyone confirm the 3803 can?
    If anyone has tried this can they share their impressions of it.
    Its to feed a pair of kef Q7's from a 3803/2900
    Dave
  2. vdeknock
    vdeknock
    I think the 3803 does not have this feature. The spare two channels can only be used to drive two separate channels which are the same source(7 channel) or a B channel in another room. The amp will drive all at the same time.
    I could be wrong!
  3. Dave777
    Dave777
    Oct 25, 2002
    480
    Gatwick
    +8
    Anyone in the UK know for sure (just in case there are any regional differences)?
    Dave
  4. Jase
    Jase
    Mar 16, 2001
    9,536
    UK
    +937
    It doesn't have the facility to do it as standard but there is a "way" around it. Not tried it personally though and wouldn't. Have a search through old posts here on the 3801/2 as someone had managed it with one of those.
  5. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +10
    You could always buy a power amp with the same gain and add it on
