Denon 3803 - Adjustable Crossover?
Discussion in 'AV Receivers & Amplifiers' started by themmings, May 17, 2003.
Tags:
  1. themmings
    themmings
    Nov 21, 2002
    380
    Northampton
    +4
    I'm not missing anything am I in saying that this amp doesn't allow you to set/adjust crossover speaker by speaker?
    I've looked at the manual, but can only see one crossover (in the sub setting) that runs across all the speakers.
    I wanted to set a different crossover point for my A'Diva centre speaker (lower) than what the Micro's would be be set at.
    All speakers are set to small, with the sub on. Crossover is at 80.
    Timbo:)
  2. Jase
    Jase
    Mar 16, 2001
    9,535
    UK
    +933
    It will allow you to adjust the crossover setting for ALL speakers not for each individual speaker. You have the option of 40/60/80/100/120 HZ. :)
  3. themmings
    themmings
    Nov 21, 2002
    380
    Northampton
    +4
    I thought so - thanks Jase.
    I've set it to 100Hz on the amp and flicked my sub to direct.
