Denon 3802
Discussion in 'AV Receivers & Amplifiers' started by DaveP, May 16, 2003.
Tags:
  1. DaveP
    DaveP
    Hi, I've just bought a 3802 from the classifieds forum and I'd like to use the remote for my tv and dvd. Does anyone know where I can download the code list from or can someone fax me the sheet?
    It maybe the same as other Denon amps/receivers
    If anyone has the list I currently only need the codes for Sony TVs and DVD players and also Panasonic DVD player codes. Maybe you could post them here.
    DaveP
  2. SamirP
    SamirP
    Apr 28, 2003
    1,303
    South Of The River
    +38
    Hi Dave
    I when I get home tomorrow I'll post the codes,
  3. DaveP
    DaveP
    Thanks mate, much appreciated.
    DaveP
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Sony TV: 0027 0080 0107 0120 0172 0177 0183 0188 0197 0277 0403 0451
    Sony DVD: 0560
    Panny DVD: 0517
    Mark.
  5. DaveP
    DaveP
    Thanks Mark, that's great. I'll give them a try.
    DaveP
  6. pat clancy
    pat clancy
    Sep 10, 2000
    1,801
    LONDON
    +29
    i dont suppose antone knows the code for telewest box,i,ve just had my old box replaced so i have the newer one i think its 4000 model,and one more query on 3802,what is the direct mode used for,rgrds pat
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Direct mode is for DVD-A & SACD. The 3802 gets the signal from the analogue 5.1 inputs and does no proccessing, this is all done on the DVD player.
    I will look the code up for you when I get home from work tonight if nobody else has posted it by then.
    Mark.
  8. pat clancy
    pat clancy
    Sep 10, 2000
    1,801
    LONDON
    +29
    mark,i thought you select ext in for dvd a ,sacd,rgrds pat
  9. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Yeah, sorry your right.
    Direct mode is with no proccessing - sound that is input is just amplified and then sent to speakers.
    What make is your Cable box?
    Mark.
  10. pat clancy
    pat clancy
    Sep 10, 2000
    1,801
    LONDON
    +29
    mark its a pace cable box
  11. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    I was afraid you were going to say that :( as Pace are not listed in the codes for cable boxes. There are dozens there, I didn't know there were that many makes of cable box :confused:
    Are there any other possable names on the box?
    If not then its a search of the net. Tried Denon site, but no support area :rolleyes:
    Mark.
