Denon 3802
Discussion in 'AV Receivers & Amplifiers' started by paiger, Aug 15, 2002.
Tags:
  1. paiger
    paiger
    Anybody know if it can convert video signals? I want an amp that I can use for video switching to my PJ via Svideo or component but will have a variety of inputs (VCR composite, DVD Svhs etc.) I just want to have one lead from the svid monitor out to the PJ.
    Any ideas?
  2. billduff
    billduff
    Mar 17, 2002
    275
    16
    Just to the right of civilisation
    No.. it can't.
    Only the higherend Denon amps can.
    I thought about this as well but unfortunatly it's a no-go. :(
  3. jGrahamD
    jGrahamD
    Feb 11, 2002
    265
    Kenwood KRF-X9995 has a universal video selector which does just that, OK if you've got around £1100 to spend.
  4. Noman
    Noman
    Usa a quality multi-core coaxes cable (6 channels) and put the right plugs in the end and you have a component-s-vhs cable which should do it.... I did it myself. About £70 for 6 meters with connectors (Supra AV-6 cable)..
