Denon 3802
Discussion in 'AV Receivers & Amplifiers' started by ashearer, Apr 15, 2002.
Tags:
  1. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    Can one of the many 3802 owners let me know if the speaker terminals take banana plugs?
    Thanks.
    Andy
  2. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    Hi Andy!! (edited!!)
    Yep! They do, just pop out the little rubber bungs with a small screwdriver and you can use the banana plugs.
    cheers
    Jase
  3. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    Thanks for the very prompt response.
    I wish I was Alan.....of course, even with his money, I still wouldn't be completely happy with my home cinema set-up!
  4. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    Canterbury, Kent, UK
    +6
    can someone please enlighten me to the benefits of 'banana plugs' I've picked up some info about these but nothing concrete.
    I have a 3802 also, do the plugs give a better connection or is it purely for an easier connection.
    Regards
  5. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    Better--doubt it, easier--definately.
  6. bob007
    bob007
    Spade connections are regarded better than banana plugs, better contact.
  7. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    Thats just silly, theres no way spades will fit in the binding posts of my amp, neither will a shovel.................:D
    Joking aside, bananas are far more convenient than having to faff about with stuffing bare wire into the binding posts. Not used spades to be honest so cant comment.
  8. bob007
    bob007
    My amp must be bigger than yours, coz i got spade connections on mine :p and the remote has a on/off function for rear speakers. :D
    Did have banana plugs up untill a month or so ago, wasn't that happy with them, so decided to go for the spades, no difference in sound, just happier with the better connection.
    cheers bob
