Denon 3802
Discussion in 'AV Receivers & Amplifiers' started by Joachim, Feb 20, 2002.
Tags:
  1. Joachim
    Joachim
    Can you use a single rear surround channel with the Denon 3802? It has speaker terminals for 2 but are they both exactly the same?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    There are actually two amplifiers, one driving each output. The signal is however MONO so you could use one only.
  3. Craig_Nike
    Craig_Nike
    Please correct me if I'm wrong (I hate to doubt you Reiner) but I didnt think the 3802 is 7x110W channel amp ?
    Last I looked it was 6x110W.
    1-L 2-C 3-R 4-SL 5-SR 6-SB ?
  4. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    No worries, anybody can doubt me and I am open to corrections and criticsm. If I don't like it I just delete it. :D
    (Just kidding about the last part!)
    The Denon AVR-3802 does however have 7 channels of amplification rated @ 105 W x 7 (8 ohms).
    Yamaha usually "cheats" you with this one as they provide only 6 channels of amplification.
    Denon AVR-3802, AVC-11SR and AVC-A1SE (to name the latest models only) all have 7 channels, see the details at the official Denon UK website:
    http://www.web-quality.ch/WQ/apres_...D=DenonUK&VKundenID=DenonUK&S=2&Anbieter=5762
    (What a weird link that is ... containing German words, too ...)
  5. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Oh, and I just noticed the AVR-2802 has 6 channels only, too!
  6. Craig_Nike
    Craig_Nike
    OK thanks Reiner - it must of been the 3801 that had 6x105W ehh ?
    BTW My Sony ripped me off with the 6x110 also with a SB, but I dont have the room for 2 speakers anyway so it doesn't bother me at all.
    Also if I wanted to oput a second one in I could just Y split the speaker wire to a second speaker couldn't I ?
  7. bob007
    bob007
    Don't think so........i have the 3801 and it has 7x105watts................. thank you!!!!
  8. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Denon provides a power amp for all speaker outputs except Surround A/B (if you have them) which share the Surround L & R amps. You set weather or not you are connecting a single rear speaker, and if you are, power to the SBR amp is cut and the processing is updated accordingly (because some of the DSP modes are full 7.1).
    Mark
  9. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Craig_Nike, you can connect two speakers: Connect in parallel if the speaker has an impedance of 8 Ohm or in series if less than 8 Ohm (e.g. 6 or 4 each).
  10. mikenruth
    mikenruth
    In the set up menu on the 3802, when you select surround back speakers "on", I believe you get an option for 1 or 2 speakers. Select 1 and use the correct (left or right) speaker terminals.
    Please forgive me if I've mixed this up with an Onkyo set up menu;)
  11. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    You are correct mikenruth
