denon 3802
Discussion in 'AV Receivers & Amplifiers' started by spielberg666, Dec 26, 2001.
Tags:
  1. spielberg666
    spielberg666
    Does anyone know the price of the denon 3802?
    Is it still worth to buy the denon3801,
    :D thanx:D
  2. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,002
    Inbetween Upgrades !
    +7,286
    The official list price of the 3802 is £850.
    Shop around and you will find a much better deal. If you want my advice stick with a local ( gold ) dealer and you will get 3 years warranty .
    Depending on your needs the 3801 can now be a great bargain. Personally i have the 3802 , and it is stupendous !!!
    Kev
  3. Colger
    Colger
    Check out Hifijunkies - I have just purchased from them - a couple of hundred pound cheaper than recommended retail.
  4. spielberg666
    spielberg666
    thanks everyone, if I can't find the 3081 for a very good price then I will buy the 3082.
    :D:D
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Go for 3802 it has PL2. Essential.
  6. BarryK
    BarryK
    Nov 18, 2001
    93
  7. spielberg666
    spielberg666
    Thanks a lot everyone.:D :D :D :D :D :D :D
