Denon 3802 & Wharfdale 750
Discussion in 'AV Receivers & Amplifiers' started by kirk grubb, Dec 31, 2001.
Tags:
  1. kirk grubb
    kirk grubb
    Sep 6, 2001
    586
    +11
    HI guys & gals,
    I have a problem connecting my dvd player to amp with a coaxial lead.
    I have gone into digital assainment in amp and changed dvd setting from optical to coaxial, but when playing a dvd there is no sound and the dolby digital light is not illuminated- just says analogue.
    So is obvious the amp is not getting a digital signal.
    I tried using an optical cable and rechanged the settings on amp and everything is fine. Its just that i would prefer to use coaxial.
    I looked in the dvd menu and the settings are on bitstream, but i cant find a menu containing an option to output coaxial or optical, so i presume the default settings are for optical.
    Also i know the dvd player is multi region with a hack, but wondered if i can get dts out of this player - there is no logo for dts on player.
    Any tips or recommendations would be greatly received.
    CHEERS
  2. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,497
    Hi Kirk
    Make sure the amp is set to AUTO.
    Press the button on the front of amp and it will then pick up all signals automatically.
    cheers
  3. DNA
    DNA
    My 750 (an early one) plays DTS just fine even though, as you say, there is nothing on the outside to say it can do DTS.
    DNS.
  4. kirk grubb
    kirk grubb
    Sep 6, 2001
    586
    +11
    HI jase
    Im sure i tried that because the manual states that to get dolby digital the best way is to use the auto button.
    I will try again to make sure i have covered all options.
    Cheers Jase
    kirk
  5. kirk grubb
    kirk grubb
    Sep 6, 2001
    586
    +11
    Cheers DNA
    I will put that into good use tonight because i got fast and the furious today :)
  6. greeny
    greeny
    Are you using a 'proper' digital interconnect (i.e. 75ohmn RCA) and not just a regular phono lead.
  7. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Does your DVD player need to be set to send out a proper digital over the digital connection, and not just an analogue/PCM signal?
