denon 3802 video switching
Discussion in 'AV Receivers & Amplifiers' started by pat clancy, Aug 30, 2003.
Tags:
  1. pat clancy
    pat clancy
    Sep 10, 2000
    1,805
    LONDON
    +29
    hi,am i right in saying that if i plug a composite signal in to amp ,the amp will convert it to svideo or even rgb at the tv end,rgrds pat
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    NO! :mad:
    The Denon that will do this is the newer 3803 or the higher models. Any video signal into the 3802 will be output as the same ie composite in = composite out ONLY! :suicide:
    Mark.
  3. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    Indeed, if the 3802 converted Comp - S-vid my problems would be solved! But it doesn't :(
    Also there's no button on the remote for the feature on the amp i use most, the video select. How annoying!
