Denon 3802 to 2805 or 3805, lipsync probs
Discussion in 'AV Receivers & Amplifiers' started by Benrudd1, Oct 16, 2004.
Tags:
  1. Benrudd1
    Benrudd1
    Jan 19, 2003
    961
    Pembroke Dock
    +66
    Hi all,
    I have recently added a Denon 2200 to my gear :thumbsup:, while pleased with the results I have started to notice lipsync issues more and more.
    As a result I am considering a receiver change but would like to keep the costs down
    Mainly looking at the Denon's as I like the sound and the feature list looks ideal. 3 component inputs, audio delay and room eq sound right up my street.
    Question is has anyone compared the 2805 to the 3802 as it is about £250 cheaper than the 3805. However I don't want to buy one and find it sounds worse than the 3802.
    Point to note. My room is tiny 3.5m x 2.5m and i'm only running the 3802 up to about -25db max at the moment
    Thanks in advance
  2. Benrudd1
    Benrudd1
    Jan 19, 2003
    961
    Pembroke Dock
    +66
    change of plan :oops:
    Have spent the weekend playing with the gear and watching a few films.
    Turns out the lipsync probs were down to a couple of bad discs, because everything else I have watched has been fine :thumbsup:
    There's a couple of hundred pounds saved :clap:
