Denon 3802 sound levels
Discussion in 'AV Receivers & Amplifiers' started by chiwan, Jan 13, 2002.
Tags:
  1. chiwan
    chiwan
    I've got the 3802 coupled with Kef eggs. At the moment for normal listening I'm using -30 to -20 and for movies i'm using -18 db (which to me is pretty loud). I was wondering is this a reasonable range to use.
    I have connected the gear up myself although I was comtemplating getting a help from the dealer. On the initial tone test settings menu I have left all levels at 0 decibels which is the default.
    Please can you provide advice on the best settings for this combo as I don't want to cause any major damage to my system/speakers
  2. Noman
    Noman
    Is that why they are called "eggs"... They get easily damaged:D I don´t know about the eggs but I can listen to my Boston Acoustics Micro 90x at 00 to +05 (Denon 3802) for long periods (and that is LOUD) and I have not noticed any distortion nor physical damage (exept for my hearing ability)
  3. Whatts
    Whatts
    My 3802 is in a reasonably small room (4x4 metres), for movies I'm usally around -20 (sometimes more if nobody is around).
    For music anywhere between -40 to 0, usually in 5stereo.
    My advice would be to listen at whatever level you like, but when you hear distortion, turn it down a little...
  4. BarryK
    BarryK
    Nov 18, 2001
    93
    My room is quite large (23ft X 13 ft) and I usually listen to movies with the volume at around -12db.
  5. greeny
    greeny
    Don't worry what levels you are listening at. As long as you're not getting distortion then no probs.
    It's imposible to be specific about these levels when compairing setups anyway, there are too many varaibles, e.g the sensitivity of the speakers being used affects the power level required by the amp a huge amount.
  6. bob007
    bob007
    The best advise i can give is to buy a spl metre, as you can set all speakers to there reference levels, some say 75db some 85db, i have opted for 75db with all speakers set to small, sub crossover set to 90/95db.
    The spl metre showed some speakers to be quite a way out with the default setting and with a set up which i had done by ear.
  7. chiwan
    chiwan
    Thanks for the replies, the main concern I have is that sometimes if I'm watching something the centre speaker shows distortion especially with shrill voices or high treble scenes - this is on a -20 to -30 db setting!!!!!
    My current amp settings are
    Fronts = small
    Rears = small
    Subwoofer = on
    Crossover set to 80 on the amp
    Treble = 0
    Bass = 0
    I hope my setup isn't damaging the speakers. Also where can i buy a spl meter and how much should I pay?
  8. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,466
    Inbetween Upgrades !
    +7,745
    Chiwan,
    What speakers do you have ?
  9. chiwan
    chiwan
    Mozzer, I have the Kef eggs
  10. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,466
    +7,745
    sorry chiwan, i spotted your speakers after i replied!
    Do you have the centre wired up correctly +to+ / -to-?
    Are the speaker cones damaged in any way?
    I have this reciever and your listening volume level is comparitively low so, that shouldn,t be the problem.
    Try switching the speakers around and see if the problem is still there.
    Kev
  11. chiwan
    chiwan
    everything is wired up correctly and the speaker cones are not damaged as far as I know.
    The speaker wire is QED silver to the fronts and centre with QED micro for the rears.
    I've only recently noticed the problem with voices although 95% of the time everythings okay. Watching DVD movies is superb but was wondering if I could optimise my set up better after spending the best part of £1500 on amp and speakers
  12. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,466
    +7,745
    There are things you can try, but it may not make the sound any better , just different.
    Probably the biggest experiment you can try is with your sub. This would include the settings and placement of it.
    Also with your surround speakers. Are they at the side or behind ( there are arguments for both, try it )
    There are also a number of tweaks on your reciever as well.
    I have the 3802 with M&K K Series.
    Kev
  13. Stewart C
    Stewart C
    That is the only option open to you get an SPL Metre, bypass UR Tones you shouldn't need them.
    Set up all speakers including sub to 75 db's you shouldn't go far wrong at that.
    Every speaker even the same kind will output different volumes depending on room acoustics etc, everyone should have an SPL metre. There are 2 many channel vying for supremacy you need balance.
    Regards
  14. chiwan
    chiwan
    Thanks for all the suggestions - I think i'm going to invest in an SPL metre. Any suggestions on type and how much to pay for it?
  15. tk2001
    tk2001
    Nov 4, 2001
    1,400
    48
    +36
    I have a Marantz SR-5200 av receiver (90W per channel) along with Mission FS2AV speakers (75W per satelite) setup in my livingroom (meduin-size) and I too have noticed that for DVD movies containing Dolby Digital 5.1 soundtracks, I had to turn up my volume levels to between -10dB (being loud) to +05dB (very loud) - I was watching the movie 'Swordfish (R1) on DVD a couple of days ago and I had my amp/receiver volume to +05 dB, and the huge 10 second explosion at the begining of the movie quite literately 'shock' the neighborhood! lol.
  16. M.Joshi
    M.Joshi
    Oct 10, 2000
    249
    Harrow.
    +9
    Chiwan,
    I noticed that you mentioned in your thread that you are using QED Micro for the centre and QED Silver for the other speakers.
    The QED Micro may be too 'Bright' for that speaker, hence you hear the shrill.
    Try substituting one of the QED Silver cables from another speaker and using it on the centre.
  17. Droogie 2001
    Droogie 2001
    Aug 19, 2001
    1,483
    Surrey
    +111
    Good post. Kind of a coincidence I was going to ask that same question about volume levels on the 3802 and the KEF Eggs.
    Some of you guys must have understanding neighbours +5db one guy mentioned!
    I've recently bought this same setup and found -27db to be more than enough, must be getting old!
    BTW Since I've bought the setup before the Xmas period I couldn't find any stands for the eggs at all. KEF are waiting for another shipment which could take 2 weeks. The speakers are easily enough to get hold of though.
    Managed to finally find some, you can't imagine how frustrating it’s been not being able to set the rears up, tried/risked dodgy cardboard boxes stacked up on top of each other but common sense finally prevailed!
  18. chiwan
    chiwan
    m.joshi
    I'm using qed silver to the fronts and centre with qed micro only to the rears - sorry for the confusion.
    I have a feeling that my system isn't fully optimized and am going to invest in a SPL metre or get the dealer to make a visit and do it for me.
  19. greeny
    greeny
    Come on then, Who's got an SPL meter?, Where from? How Much?, Any Good?
  20. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,497
    Greeny
    You can get a sound meter from Tandys. I picked up the Digital version for 15 quid around 18 months ago. Well worth it for the money, its the only way you can balance everything perfectly, unless you´ve got amazing hearing!
  21. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,466
    +7,745
    Chiwan,
    I have an SPL meter, where do you live. Maybe i can help with your setup.
    Kevin
  22. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,220
    n/a
    +306
    got my SPL from maplins.
    £49
    dvd
