denon 3802, sound level meter.
Discussion in 'AV Receivers & Amplifiers' started by beavis2ooo, Aug 8, 2004.
Tags:
  1. beavis2ooo
    beavis2ooo
    Hi there, could anyone please tell if it is worthwhile investing in a sound level meter?, and if so where could i buy one from?. Manyn thanks.
  2. Sab
    Sab
    Dec 18, 2002
    754
    London
    +26
    Yes it is well worth getting a sound level meter. This adjusts the speakers so that the sound pressure in all the speakers is the same and I believe it produces a more realistic sound.
    Set sound level meter to slow and weighting C.Adjust via test tones so that all the speakers reach 75 DB.
    You can buy a DIGITAL sound pressure meter from Maplin for £50. Analogue version is also available but I would go for the digital version.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    analogue unit is more reliable and used by DVE and AVIA Cornwall electronics £25 have a search
  4. Miniholic
    Miniholic
    Apr 26, 2001
    3,046
    The Shire
    +398
    Keene have got the Radio Shack analogue ones back in for £25, I'll be ordering mine next week.
    Keene
    Do a search for item no SLM2050
  5. CosmicOne
    CosmicOne
    why do u think the analogue is better??i also want to buy one & i have analouge & digital also from radioshack & i don't know what's better to get??
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    well digital looks accurate but is no more accuarate than analogue, its twice the price for digital and almost all calibration discs have analogue model in them.
  7. nikyzf
    nikyzf
    I've just bought the analogue Radio Shack from Keene, £27.49 inc P&P; arrived next day. The digital one is £40 exc P&P. The analogue display is marked in dB but you can easily estimate to a higher resolution, 0.5 dB say. AFAIK the digital one displays only whole dBs, so you are stuck with that.
    BTW these meters do not have a flat response down to subsonic; however, the correction factors are well established.
  8. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,526
    Near London.
    +208
    Nobody's sure how the old correction factors apply to the new meter.
    I think analogue is better as it's a bit easier to spot the trend. Same as digital speedos in a car aren't as helpful as an analogue dial.
  9. beavis2ooo
    beavis2ooo
    Thanks for the info, useful & much appreciated.
