Denon 3802 - Setup Small/Big Speakers
Discussion in 'AV Receivers & Amplifiers' started by smind74, Mar 26, 2006.
Tags:
  1. smind74
    smind74
    Mar 8, 2005
    348
    Horley
    +5
    Just a quickie.
    I had a full set of KEF 5005 satellite speakers and as such set the amp to small speakers for all of the channels.
    I've upgraded the front left and right to KEF 9000's (3 * 6.5inch drivers), and so would I change the front left and right channels to Big speakers or leave them as small as they are designed to be supported by a sub.
  2. limegreenzx
    limegreenzx
    Feb 9, 2006
    2,018
    +337
    Keep set as small. Crossover will also stay the same.
  3. tonyrees687
    tonyrees687
    Mar 20, 2006
    2,767
    Iver Heath Bucks
    +436
    ive the same amp with ruark vita speakers ive fiddled around with speaker setting and found that set to Small works better and sub at 120 htz works good im my room
    good luck happy experimenting
    regards tony
