Denon 3802 setup problem
S
spycon69
I have its monitor out (both s-video & composite plugs) connected to the projector. I try to enter the setup menu on Denon 3802 but seems impossible to do so. I tried the OSD button without any results ? Any help ?:confused:
S
spycon69
Yes, all menus on the remote toggles correctly (as seen on the lcd screen) but nothing happens on the receiver. I've tried both s-video & composite output without a result.
Jase
Make sure the LCD screen shows AMP before you press the setup button. If it still doesn't work it might be worth resetting the amp completely. The manual will tell you how. Just check under Re-Initialization of the Processor.
