Denon 3802 - Optical or Coax?
Discussion in 'AV Receivers & Amplifiers' started by Tim Ingman, Sep 24, 2001.
Tags:
  1. Tim Ingman
    Tim Ingman
    Nov 2, 2000
    32
    9
    I'm thinking of buying the Denon 3802, but apparently it has only one digital coax input. I need to connect DVD and Digibox. Any views whether I would notice any degradation/improvement/no difference at all if I went optical for the DVD connection? <br />Also, best deal for the 3802 anyone?
  2. Metric
    Metric
    it doesnt really matter, bits are bits, though some argue different... but there ya go, got mine from hotkit for 569 but that was a while back, dont know what it is now, think the best price is hifijunkies
  3. Paden
    Paden
    Jul 27, 2000
    573
    +19
    Just to let you know that the Sky+ box only has an optical output.<br />Cheers, Paul.
  4. Confucius
    Confucius
    Feb 1, 2001
    2,148
    Oxford
    +132
    To (mis)quote that well known Whiskas advert:
    8 out of 10 owners (who expressed a preference) said their ears preferred co-ax.
  5. Leon Rees
    Leon Rees
    Co-ax should be better than optical/TOSLink.
    The TOSLink connections are bandwidth limited. So, make sure you connect your highest quality source to the coax.
    HTH.
    Leom
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    If you go for coax make sure you buy a digital cable (75Ohm), else it will sound worst than optical, especially with PCM (CD-Audio).
  7. jlanng
    jlanng
    Aug 20, 2001
    Go to the expense of coax if it's raw data (as from a CD player or a sky box), or optical if it's packetized AC-3 (Dolby Digital).
    You can buy dongles to convert between the two formats if you run out of connections
