denon 3802 offset +4db
Discussion in 'AV Receivers & Amplifiers' started by jonnyv, Aug 22, 2004.
Tags:
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,262
    48
    +49
    got a denon 3802 amp to replace my pioneer amp which used to display +4db when watching a film in dolby digital, the denon instruction book says this dialogue normalization is achieved automatically when playing dolby digital program sources, but ive never seen the display state 'offset +4db' etc.
    is this normal, i dont listen at reference level normally -30db from reference.
    thanks
  2. Arcangel
    Arcangel
  3. jonnyv
    jonnyv
    Mar 31, 2002
    2,262
    48
    +49
    Thanks for the reply. The manual states the dialogue normalization status can be displayed by pressing the 'status' button on the amp, ive done this and cant find any info on the dialogue normalisation.
    No problem with it not showing it, the amp is excellent !
  4. Arcangel
    Arcangel
    My Denon flashes it up on the display onces it starts to decode the Dolby signal. Presumably if the 3802 shows it when pressing the Status you have to keep pressing the button until it shows OFFSET +4db or whatever. :)
  5. jonnyv
    jonnyv
    Mar 31, 2002
    2,262
    48
    +49
    i shall try again, but im sure i pressed it loads of times till i got back to where i started from !
  6. Arcangel
    Arcangel
    I don't remember my 3801 (same as 3802 but without Dolby PLII) having the feature so maybe the manual is wrong??
