Denon 3802 - no dolby digital light!
Discussion in 'AV Receivers & Amplifiers' started by Brad_Porter, Jul 29, 2002.
Tags:
  1. Brad_Porter
    Brad_Porter
    Dear all,
    I have a Denon 3802 and upon performing a full system reset I find that there are two red led on the right hand side. One is the 'Pro-logic' LED and the other is the Dolby Digital LED.
    The issue is that when the amp is playing a 5.1 source it comes up Dobly Digital in the main display, it flicks from 'anologue' to 'digital' on the bottom right, but this seemingly useless red LED(just next to the red pro-logic LED) does not appear.
    Does everyone else get this issue? Do you all get the red dolby digital light when you play 5.1?
    The sounds that comes out is definately dolby digital and everything else sounds normal.
    I wonder what is going on. Can you help?
  2. Jase
    Jase
    Mar 16, 2001
    10,819
    United Kingdom
    +2,695
    Hi Brad
    Most of the Denon´s have LED´s that don´t actually light up.
    As long as you have it set to AUTO it will decode any signal you send to it. You´re getting Dolby Digital coming up on the main panel so thats the important thing.
  3. Brad_Porter
    Brad_Porter
    Thanks Jase.
  4. Sly
    Sly
    Apr 28, 2002
    1,519
    west mids,England.
    +52
    mine does!
    dont what i might have done different to you though.
    thats proberly not much help...............sorry.
  5. Dom H
    Dom H
    You mean the 'Dolby Digital' sign on the far right of the display under the 'Pro Logic' sign not the Dolby Digital 'led' on the left under the signal section don't you?
    My DD led lights up on the left but not the DD sign on the far right.
  6. Sly
    Sly
    Apr 28, 2002
    1,519
    west mids,England.
    +52
    yep,them ones.
  7. Brad_Porter
    Brad_Porter
    The light I am reffering too is best discribed as this.
    When you play/select ProLogic on the amp, the RED 'ProLogic' LED lights up on the far right. Just below the RED 'ProLogic' LED is another RED 'Dolby Digital' light that when I play a Dolby Digital Source, it does NOT light up.
    The main display says 'Dolby D' and the source flicks from 'Anolologue' to 'Digital'. However, no RED 'Dolby Digital' LED is displayed.
    Does this make more sense? I just want to know, if you play a dolby digital source or a DTS source on the 3802, is there any RED LED displayed on the right?
    Cheers so far guys. I know I am bad as explaining!
  8. Jase
    Jase
    Mar 16, 2001
    10,819
    United Kingdom
    +2,695
    No.
  9. Brad_Porter
    Brad_Porter
    Cheers again Jase.
    Mate - Im a little upset you know. I have ordered stack loads of equipment and I have to wait 2.5 weeks until it all turns up. Until then I am stuck with TV speakers.
    Hoe on earth does one get over this - ITS DRIVING ME MAD!!!
  10. Jase
    Jase
    Mar 16, 2001
    10,819
    United Kingdom
    +2,695
    I can sympathise. I was without my amp for 7 weeks whilst it was upgraded in the UK.:( Sound through the TV is so naff in comparison! Actually I´m without sounds at the moment as I´ve blown the tweeters in my front speakers!! (got some new toys arriving soon though!:D ;) )
  11. Brad_Porter
    Brad_Porter
    How did you blow your tweeters? Dear dear dear......I thought you experts would have learnt by now......:D
  12. Jase
    Jase
    Mar 16, 2001
    10,819
    United Kingdom
    +2,695
    :blush: Not entirely down to me!! Seems they were faulty. I don´t run the system loudly so just seems one of those things that happen!:(
  13. bob007
    bob007
    Will you be blowing these toys up as well.:D
  14. Jase
    Jase
    Mar 16, 2001
    10,819
    United Kingdom
    +2,695
    I´ll try not to!:D
  15. bob007
    bob007
    Whooshhhh, that's the sound of the blow up doll flying over your head. :D :D
  16. Jase
    Jase
    Mar 16, 2001
    10,819
    United Kingdom
    +2,695
    Do you speak from experience?:p :D
  17. bob007
    bob007
    :blush:
  18. Dom H
    Dom H
    At least you lot didn't have every piece of your HT equipment destroyed by a lightening strike! I was without for at least 5 weeks. Not nice, not even any tv speakers!!
