Originally posted by keyser
Got it, but can I change the bass/treble from the remote?
So I do have to go through changing bass and volume for surrounds everytime I play something in dp2?
You can't change the bass/treble from the remote, but you can change it from the front panel of the amp, not ideal but it's better than connecting the lead up for the onscreen menu if it's not convenient to have the cable connected all the time. IMO the bass/treble should be left at "0", just adjust the LFE channel for a little more bass.
When you set the speaker levels these levels apply to DD, DTS, Neo6 and DPL2, you shouldn't have to adjust any levels. If you find that the source you are playing requires the bass/rears adjusting then you will have to re-set the levels by using the method I explained earlier via the remote, that's if you don't want to connect the cable up for the OSM.
The amp will not memorize different settings for DD, DTS, Neo6, and DPL2.
