denon 3802 learning remote codes
Discussion in 'Home Cinema Control & Remote Controls' started by soulbrother michael, Feb 24, 2002.
  1. soulbrother michael
    soulbrother michael
    Got my new 3802 last week,it came with a leaflet containing the various codes of different manufacturers,i have mislaid it and i want to programme my remote control.If anyone has the codes for PIONEER,PHILLIPS ,and MARANTZ i would be really grateful
  2. deang
    deang
    Try using the auto-search facility. This will search through the list of available codes and when it finds your components (which must be 'on') you stop the search.
    I tried it to try to find my cable remote. It didn't find it, but that's becasue the cable remote uses IR codes / frequencies outside the normal range.
  3. burkey
    burkey
    if u r still having problems e-mail me i can send / fax a copy of codes to you.
    [email protected]
