Denon 3802 dolby digital ex
Discussion in 'AV Receivers & Amplifiers' started by falcon-20, Apr 3, 2005.
Tags:
  1. falcon-20
    falcon-20
    Apr 3, 2005
    2
    Hi, this is my first time in an av forum and my question is this, does anybody know if the denon 3802 decodes dolby digital ex?. If it does what will be shown in the display, and is there any specific switching or menu setting that i should do. I am sure it should but it is not mentioned in the instructions or as a logo on the case.
  2. Miniholic
    Miniholic
    Apr 26, 2001
    3,048
    The Shire
    +398
    When the 3802 was released EX was only offically allowed on THX approved products (it was then THX EX, DD EX wasn't available as a home format until the following year), however, you can force the 3802 to decode it by switching on the surround back speakers manually.
    As EX is matrixed into the surround channels (not discrete like DTS 6.1 can be) doing this means that the amp is able to decode the signal.
  3. falcon-20
    falcon-20
    Apr 3, 2005
    2
    Thanks for the info Ian, what should the display show when in EX ?
  4. Miniholic
    Miniholic
    Apr 26, 2001
    3,048
    The Shire
    +398
    Sorry, no idea mate. I'm running 5.1 at present, 7.1 is on the cards for next year, got to get my projector first though. :)
  5. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    falcon as far as i can remember my 3802 used to just display dolby digital 6.1 when playing 5.1 or ex dolby signals
  6. S H A D O
    S H A D O
    Mar 16, 2001
    10,298
    United Kingdom
    +1,574
    It will probably show 6.1 Surround on the Display. :)
