Denon 3802 digital inputs
Discussion in 'AV Receivers & Amplifiers' started by tom_nieto, Nov 3, 2003.
Tags:
  1. tom_nieto
    tom_nieto
    May 21, 2003
    418
    Brighton
    Is there any way to reassign the digital inputs on my denon 3802 without using the OSD. It's being used as an amp with my computer, and I don't have a video input on my graphics card. The manual insists that I have to use the OSD to reassign the digital inputs via the OSD, but I'm sure there must be a way with the remote control and the buttons on the front... unless I'm very much mistaken.
    Basically, I want the DVD audio input to be optical 1. Eventually I also will have my CDP input at optical 2, but that can wait a bit.
  2. Jase
    Jase
    Mar 16, 2001
    9,410
    South Coast
    +857
    I don't think so. To be honest, Denon's are so easy to setup with the OSD that I've never tried without it.:blush: Could you not pinch a small portable TV for a while just to use it for quick setup?
  3. tom_nieto
    tom_nieto
    May 21, 2003
    418
    Brighton
    I'm going to borrow a mate's TV tonight, I think it'll be lighter and easier than lugging the thing downstairs to his TV to be honest.
