Denon 3802 Dead Remote Help
Discussion in 'AV Receivers & Amplifiers' started by typing00, Sep 27, 2004.
Tags:
  1. typing00
    typing00
    Dec 4, 2002
    104
    Just purchased a Denon 3802 with a dead remote, and finding no luck trying to utilise the coaxial input (I believe that digital input is currently set at Optical 1). According to the manual the only way to select the digital input is via the remote, has anyone tried setting it manually?
    Thanks.
  2. Arcangel
    Arcangel
    You need to access the OSD to be able to assign the digital inputs. The only other way to do it is by trial and error to see which input it's already assigned to. Plug into the Coax Input, play a CD and then manually select each different Input to Input eg. DVD, CD, TV/DBS etc until you hear sound. :)
  3. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    Land of the Living, Essex
    +37
    Coax is assigned to tv or cd by default i think.
  4. typing00
    typing00
    Dec 4, 2002
    104
    Newbie here, OSD = ?
    I am actually connecting the 3802 (coax in) to a Denon DVD2800 (coax out) via a Coaxial cable, are you saying that even if I select CD it might receive the coax signal?
    Thanks again.
  5. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    +37
    you'll get the OSD if you connect monitor out on the amp to a TV.
    CD or TV are default for coax so if you select that you will get the sound from whatever is plugged into you coax in.
  6. Arcangel
    Arcangel
    On-Screen Display. :)
