denon 3802 can anyone get 1 in southern ireland
Discussion in 'AV Receivers & Amplifiers' started by j.fitz, Nov 9, 2001.
Tags:
  1. j.fitz
    j.fitz
    hi ,am trying to get the above but to no avail .heard it will be the start of december before any will be available .dont want to get it over the net.
    anyone had any luck.regards jimmy.
  2. mjn
    mjn
    May 24, 2001
    23,546
    Herts, England
    +11,958
    give up mate......you can't get sh*t in this country!!!
    Believe me, save yourself the hassle, fly to the UK, and buy your goods, then fly back......with ryanair flights from £3IEP, you can't go wrong.....or go over on ferry..its cheap at the minute..with it being winter...
    It'll cost you the same or less!!! Thats whats i've been doing!!
    one place to try is www.cloneyaudio.com is Blackrock, Dublin, they do stock a lot of stuff!!
  3. kev_c
    kev_c
    Lyric HiFi in Dublin stock Denon. They are in Lower Stephens Street Dublin 2.
    HiFi Corner on Aston Key do Denon also but dont stock all their products as far as I know. I'd try Lyric first.
