Denon 3802 and Sony 32FQ75
Discussion in 'AV Receivers & Amplifiers' started by astonbilla, Aug 11, 2002.
Tags:
  1. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    Does anyone have their amp under their TV?
    I am beginning to think myabe my amp has caused geometry problems with my TV. The screen seems to bend ever so slightly upwards in the centre of the screen. I was wondering if maybe the Denon amp was causing this.
    I have it on the lower shelf of the TV stand - i was hoping that this was far enough away. Also i had my Sony db940 there for 2 years.
    Hopefully i'm just being daft - so could anyone tell me if i'm being paranoid or if i do need to move the amp?
    Bill
  2. pwoody
    pwoody
    You are not paranoid! My Denon caused colour patching effect at the bottom of the screen when it was directly underneath with about 7 cm clearance from bottom of TV. I cured it by switching TV off in order to Degause the screen after advice from other members. I have since moved amp to the left so that the tranformer in the Denon in no longer underneath the tv & so far all seems well.
  3. dts_boy
    dts_boy
    Nov 26, 2001
    2,587
    Manchester suburbs...
    +178
    my amp, denon avc a1se is under my toshiba 36zp18 and doesn't cause any problems, it fits quite well with a glass shelf taken out. there is a bout 25-30cm above it though as it does get quite warm
  4. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    Thanks guys - like i said its not so much purity problems, its more like geometry as if the screen is being pulled and pushed. I have decided to move all my AV gear and put the TV in another place.
    Can anyone recommend some decent and cheap av furniture?
    Fankoo
    Bill
