T
Trig
Dear All,
Just a quickie regarding the 3802. Manual of guidance not too helpful, so out to you.
Am I correct in assuming that when I listen to music in the Direct mode the signal that is being amplified is unfettered by any processing ?
The reason I ask is when I listen to music for example I seem to get the full bass sound from my fronts. When I select any other mode including stereo the bass noticeably drops off. No other settings have been changed in the other modes, levels etc. (I can actually see the cone moving less for a given volume.) This only happens when the fronts are selected as small in the setup. If they are selected as large there seems to be no difference in the bass they produce whatever mode is used.
Dave
Dave
