Denon 3802 & 6.1 speakers.
Discussion in 'AV Receivers & Amplifiers' started by Desticado, May 10, 2002.
Tags:
  1. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    Canterbury, Kent, UK
    +6
    I've just bought a 6th KEF Egg speaker to use as the rear centre channel for 6.1 on my Denon 3802.
    Since there are two 'B speakers' on the Denon does it make any difference which one I connect it to?
    Is there anything I should be aware of as I make this tip toe journey out of 5.1 and into ES/EX territory.
    Many thanks in advance.
  2. Craig_Nike
    Craig_Nike
    I fairly sure it doesnt matter which one.
    The EX / ES signal is mono anyway so it is the same signal being sent to both speakers.
    IF you are using DiPoles on the rears and sides there is a school of thought that you reverse the L&R on the Backs to cancel out dead spot or something - but if you are using 1 speaker your OK.
  3. Pzycho
    Pzycho
    On the A1SR I need to connect it to the Left Rear output as I'm only using one rear centre - unless I select two from the speaker setup of course, as it then outputs on both channels.
    The 3802 may or may not be the same ;)
  4. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    +6
    Well I think I guessed right :) Connected the single speaker to the L terminal of the [Surround Back / Multi Room] terminal. Entered the menue and set surround back speakers to on and to single.
    Inserted Gladiator DVD and the amp switched to DTS ES Matrix
    Nice n Easy in the end (not counting having to rip out all the skirting that i only put down 2 weeks ago, in order to lay another cable... DOH)
    The scene where the gladiators first go in to the arena in (I thin) tunisia has an ox head fighter swinging a flail. The extra speaker really does lend itself to the sound of the flail 'whooshing' around you in a complete circle.
    Regards
  5. bob007
    bob007
    You think that was good, wait till you hear DTS ES discrete.
    You will find it works well on some soundtracks but not on others.
    Happy listening.
    Cheers bob
  6. Zig
    Zig
    Can you recomend a good DTS discrete disc?
  7. bob007
    bob007
    Seven
    Rush Hour 2
    Gladiator
    The Haunting
    Chicken Run
    I think the latest version of Highlander is 6.1 dicrete.
    cheers bob
  8. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,494
    United Kingdom
    +2,030
    The discs Bob has mentioned are all Region 1 apart from Se7en which is DTS Discrete in both R1 & R2.
    The Haunting is an awesome soundtrack, probably the best.:)
  9. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    +6
    hmmm
    My Gladiator disk R2 is flagged by my denon 3802 as ES Matrix
  10. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,494
    United Kingdom
    +2,030
    Gladiator R2 is ES Matrix only. Its only Discrete on the R1 disc.
  11. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    +6
    bugger, might have to swap it then.
  12. Zig
    Zig
    I have just got The Haunting from Future Entertainment (from another post I heard sound was excellent but the film a bit crap). Unfortunatly it must of been late and I ordered the DD not DTS. I didn't realise until I put the disc in the player and was mortified! Anyone fancy buying this so I can justify ordering the DTS one?
  13. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    +6
    try it in the trading forum
  14. bob007
    bob007
    As it happens we have all forgotten Rush Hour R2 which is also 6.1 discrete.
  15. Epithet
    Epithet
    Concerning the original question, page 8 of the 3802 manual confirms that you connect a single rear sapeaker to the left channel.
    rgds
    Epithet
  16. petrolhead
    petrolhead
    Mar 29, 2002
    4,805
    87
    Newcastle
    +118
    Craig, can you expand. Interesting point about dead spot.
  17. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    +6
    I think the dead spot would be me (killed by my wife) If I bought any more speakers....
    :rolleyes: :(
  18. petrolhead
    petrolhead
    Mar 29, 2002
    4,805
    87
    Newcastle
    +118
    Yeh, I know what you mean. Bought 2 pair of rear in the last 2 weeks :eek:
