Denon 3801 plug
Discussion in 'AV Receivers & Amplifiers' started by overkill, Nov 26, 2003.
Tags:
  1. overkill
    overkill
    Nov 6, 2003
    11,842
    Murkeyside
    +1,205
    Just picked up one of these on ebay. Came with a two pin plug and an adaptor which was busted!!! I would normally strip back the cable and attach a normal three pin, BUT it's not for me so i can't be blase!!! Anybody else done this?
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,438
    United Kingdom
    +1,820
    Not a problem, just change the plug. I have to do the same for any kit I buy from the UK as I need a 2 pin plug. :)
  3. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    It sounds like many of the previous models also(I had an 1802 some time ago)which has a 2 pin plug the fits inside a 3pin adaptor plug that clips over it.
    You should be able to buy and use a 2 pin adaptor if it is only the adaptor that's broken,and if not remove the moulded 2 pin plug and replace it.
