Denon 3801 LED Display
Discussion in 'AV Receivers & Amplifiers' started by Tony McG, Nov 22, 2001.
Tags:
  1. Tony McG
    Tony McG
    Does anyone know if there is a way to modify the display for the input selected?
    I've just connected my 1st ever digibox and would like the display to say Sky or Sat?
    I've owned Sony AV receivers in the past and they have the option to modify the display so can it be done on the Denon??
  2. Jase
    Jase
    Mar 16, 2001
    10,808
    United Kingdom
    +2,693
    I dont think you can modify it. You just get the mode displayed : Pro-Logic, DTS etc etc and the relevant little red light lit up on the front panel, DVD, CD etc etc
    Dont remember seeing it mentioned in the manual when i had my 3801.
    cheers
