Denon 3801 learning remote codes?
Discussion in 'Home Cinema Control & Remote Controls' started by jasonb, Mar 4, 2003.
  1. jasonb
    jasonb
    Does anyone know if this remote can be used with a projector and if so where would I be able to find the codes or can I just use the learning function. I also want to control a remote fan, I only brought it because it had a remote and I thought that it might be quite funky to have a summer macro, bit cold at the moment though! Would I be able to control this as well. I've not recieved it yet as I've just brought it from one of the other guys on the forum, so as yet I've not had a chance to try it out.
    Cheers:smashin:
