Denon 3800 DVD Audio hook up question
Discussion in 'Blu-ray & DVD Players & Recorders' started by buzlightyear, Apr 8, 2003.
  1. buzlightyear
    buzlightyear
    Oct 8, 2002
    959
    46
    London
    +119
    Whats the best way to hook a Denon 3800 to a Denon 3802 for DVD audio. Im using Coaxil for DVD, and i guess I would use normal Analog for DVD audio but confused as to where i should plug them into? Many thanks
  2. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    DVD-Audio is mainly sent from player to amp by analogue connection (though some newer players/amps have proprietary digital links).
    Use 3 analogue audio paired interconnects and connect them to the equivalent sockets from the 3800 to the 'ext in' input on the back of the 3802.
    To listen to DVD-A you then just press the 'Ext In' button on the 3802 remote.
    Regards,
    Ian Guinan
  3. buzlightyear
    buzlightyear
    Oct 8, 2002
    959
    46
    London
    +119
    many thanks Ian, will give that go.
  4. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
