Denon 3312 - DTS
Discussion in 'AV Receivers & Amplifiers' started by mavers, Jan 9, 2012.
Tags:
  1. mavers
    mavers
    Mar 1, 2011
    89
    I am running the Denon 3312 with a monitor audio 5.1 setup.
    I have two queries:
    1) When watching movies with DTS the volume is a lot quieter. I've checked the settings and have made sure that I have Dynamic Volume off. Is there any reason for this?
    2) Occasionally the subwoofer doesn't come on. Its happened so infrequently (three times in 8 months) so I haven't really dug around the settings. Is there anything i can quickly do to on the amp to do a test?
    Thanks.
  2. Jase
    Jase
    Mar 16, 2001
    10,707
    United Kingdom
    +2,451
    Are these blu-rays you're referring to as it could just be down to the disc mastering. In the old DVD days DTS tracks tended to be louder than their Dolby counterparts.
    As for the sub is it permanently switched on or left on auto?
  3. mavers
    mavers
    Mar 1, 2011
    89
    Sub is switched on auto (by signal), and it's a Monitor Audio 370HD.
    Had the same issue yesterday. Sub had the "standby" light on, and when playing a particularly bassy track it did not switch on. The back of the sub was hot to touch. Gave it ten mins and it then switched back on and it worked perfectly. Seems like the sub is entering some sort of protection mode. I'm a little surprised by this as the sub is only 8 months old and the room is well ventilated. I imagine its over heating?
    Additionally i've tried to connect the sub to the amp via the 12v trigger, though i get a hum from the sub woofer when its connected this way. It was connected via a mono cable, so i'm going to buy a stereo one to see if it will make any difference.
  4. Jase
    Jase
    Mar 16, 2001
    10,707
    United Kingdom
    +2,451
    Stereo cable to the sub might do the trick so definitely worth trying that. I know that's worked in the past for some subs.
