Denon 3300 problems
Discussion in 'AV Receivers & Amplifiers' started by dood, Apr 27, 2005.
Tags:
  1. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    I have a denon AVR 3300. It has a fault whereby sound to all channels cuts off intermittently. When it works it's fine. Isent it abroad to the denon agents who said that there was a dry joint on the digital board which they sorted out. However the problems persist. To send it back will cost more and I'm not sure if I should spend more and risk not getting sorted. Does anyone have any experience with this?
    A friend of mine is keen to upgrade his 2802 for a 3805. If he does I could buy his 2802. This has lower output than the 3300 but is 6.1 instead of 5.1 and has prologic 2. Is it advisable to buy it or is there a risk that after a while it may also go the way of the 3300?
  2. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Have you tried resetting the 3300? I think you press on the front panel the two buttons closest to the headphone socket. Go right fromt the headphone socket and you have 5 buttons for input. The two of these closest to the headphones are the ones. Hold these and turn on.
  3. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    Did a reset but unfortunately in the process of re-doing all the settings the problem recurred. In addition, I cannot do a test tone any more as there is no sound, even when there is sound on normal playback.
