Denon 2930 Question
Discussion in 'Blu-ray & DVD Players & Recorders' started by cmsjkung, Jan 5, 2007.
  1. cmsjkung
    cmsjkung
    Jan 5, 2007
    How can i config my 2930 to output video signal via HDMI and output audio
    via coaxial cable.
    thanks
  2. Jase
    Jase
    Mar 16, 2001
    10,873
    United Kingdom
    +3,041
    The digital output should be set to NORMAL. Then from the front panel or remote press the HDMI SELECT button to choose the HDMI output (YCbCr, RGB or PC) then press the HDMI FORMAT button to select the resolution you want.
    Also make sure you set the AUDIO/VIDEO SYNC option to HDMI as well.
  3. cmsjkung
    cmsjkung
    Jan 5, 2007
    thank Jase....
    :thumbsup:
