Denon 2930 calibrate
B
bappy
Should I put the IRE "0" or "7.5" when calibrating my Pj. Please help.
Thansk,
bappy
KenB2
Its generally 7.5 for NTSC CD sources (for example, region 1 DVDs) and 0 for PAL (region 2 DVDs). So it is down to the calibration test pattern source you are going to use, you'll need to use both if you go for a multi-region setup.
Ken B.
