denon 2910 sacd connection
Discussion in 'Blu-ray & DVD Players & Recorders' started by alpappy, Jul 10, 2005.
  1. alpappy
    alpappy
    Hi If anyone has this Dvd and are playing SACD's please advise if it only does so with analogue connectors as I cannot get any sound to come through using the optical or coax out. If so do I loose my 5. 1 digital on the dvd side?
    thanks
    alan
  2. deanym
    deanym
    May 29, 2004
    1,784
    +141
    Use the multichannel analogue out. DVD's will still come through your normal digital connection, but on the 2910 it has no provision for digital hi res out. :thumbsup:
  3. nevC
    nevC
    Oct 13, 2002
    109
    Ireland
    +3
    Are there any players at or near that price that output SACD multi channel digitally? The 2910 is the machine I had intended to upgrade to for DVI as well as SACD playback.
  4. Jase
    Jase
    Mar 16, 2001
    9,341
    South Coast
    +834
    The Denon 3910 has both Firewire and Denon Link (Denon Link 3 can now pass SACD). You'll need an Amp with Firewire and/or Denon Link 3 inputs. It can also pass multichannel audio via HDMI (except SACD) if you have a compatible Amp.
  5. HMHB
    HMHB
    Nov 11, 2001
    25,459
    Nottinghamshire
    +3,762
    I assume my 3805 Amp has Denon Link 3 ?
  6. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    You Bet !!! - but you'll probably have to get the fw upgrade that has recently been released to get DL3 to work properly
  7. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Do amps such as the 3805 decode the SACD or is it simply converting a digital signal to analogue? Must admit I'm struggling ot see the point of passing an SACD signal out digitally. Surely a dedicated SACD player is the best place to manipulate/decode the SACD signal?
    ...PJ :)
  8. Jase
    Jase
    Mar 16, 2001
    9,341
    South Coast
    +834
    The Firmware upgrade is needed for the player not the amp. The 3805 has Denon Link 3 but up until recently none of their players were able to pass SACD digitally to it.
  9. Jase
    Jase
    Mar 16, 2001
    9,341
    South Coast
    +834
    The 3805 can accept the pure DSD signal via Denon Link 3. The advantage is that bass management etc is done by the amp rather than the player. Most SACD players have limited bass management options. You also only have one cable running from the player rather than six. :smashin:
