Denon 2910 Multiregion
Discussion in 'Blu-ray & DVD Players & Recorders' started by NickHack, May 9, 2005.
  1. NickHack
    NickHack
    Apr 12, 2005
    43
    9
    Looking to buy a decent DVD player. I'd love to stretch to the 3910 but I think I have got to try and be reasonable!!
    Anyway I've seen it MR for £470.
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=3316&item=5772908026&rd=1&ssPageName=WDVW
    Just wondered if anyone knows whether buying imported version would be problematic? I've seen it for a similar price at unbeatable. What kind of price is it if I was going to buy one from them and then have it made MR?
    Also I've read on the forums about firmware updates that can make it multiregion. Can anyone confirm these work?
    Thanks in advance
    PS: Feel free to suggest alternatives at around the £500 mark!!
  2. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    Some good deals on arcam players about at the moment.I am going to demo a dv78 today[£470 ex demo].
  3. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    i don't think you'll find many arcam dv78 for that price....thats a realy good deal! the 2910 can be made MR with a software update but not sure where you get the cd from.
  4. deanym
    deanym
    May 29, 2004
    1,787
    +141
    The multiregion firmware upgrade is available as a download on this forum, I believe this also makes a non MR unit multiregion. If not, I have the disk which I could copy and forward to you.
  5. Unlight
    Unlight
    Jan 6, 2003
    1,438
    38
    Belfast
    +9
    NickHack - at £470, I really wouldnt bother with importing - its more hassle than what its worth for a £30 saving.
    I would recommend you buy it from www.petertyson.co.uk - I just got one last week from them for £499 delivered, brand new multiregion, will save you any worry!
