denon 2910 lines at top and bottom of screen...
Discussion in 'Blu-ray & DVD Players & Recorders' started by josaka, Jan 6, 2005.
  1. josaka
    josaka
    Nov 7, 2004
    33
    hi
    got a 2910 and a 1710
    using an epson tw200 through prog component
    anyhow...
    I am experiencing lines at the top and bottom of the picture on certain dvds but the problem is far less on the 1710 with the same dvd and connections... its a bit annoying!
    is it macrovision?
    or something more sinister?
    any others with this problem?.. I called denon uk they seemed oblivious!
    also when I was looking at the machine before buying I noticed these lines
    on 2 fast 2 furious(the demo they used!) but the lines did not appear on
    the 1910 they had hooked up I thought it might be down to the connection
    but obviously not!...
    tar
    j sk
