Denon 2910 help
Discussion in 'AV Receivers & Amplifiers' started by higenbs1, Mar 10, 2005.
Tags:
  1. higenbs1
    higenbs1
    Aug 16, 2002
    460
    +11
    Does anyone know if the 2910 will output a 720p/1080i signal via it's analogue component connections. Or is this level of signal only available via HDMI/DVI?
  2. higenbs1
    higenbs1
    Aug 16, 2002
    460
    +11
    Bump
    Anyone....please!!
  3. jamartin
    jamartin
    It appears that the video output is adjustable (480p,720p, 1080i) only through The HDMI/DVI output. The component out will pass 480p and 480i, and the composite and S video upconvert to 480p through the component outut. The 5910 does upconvert the component signal to 720p and 1080i- but this unit costs $3500
  4. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    Actually for 2910 -
    the output via DVI/HDMI can be 480p (NTSC @ 60Hz) / 576p (PAL @ 50Hz) / 720p & 1080i (@ 50/60Hz depending on input)
    the output via component can be 480i/480p (NTSC @ 60Hz) or 576i/576p (PAL @ 50Hz)
    composite and s-video are not upconverted, standard output (non DVI/HDMI) is always component and composite/s-video are taken from it and converted to their respective output
  5. higenbs1
    higenbs1
    Aug 16, 2002
    460
    +11
    Thanks chaps. I thought that this was probably the case!
