Denon 2910 HDMI Connection problem
E
EBT
I just purchased a Denon 2910 and 60" Sony SXRD TV. The Denon is attached directly to the TV via HDMI at 1080I. I cannot get a picture. The display on the Denon shows a flashing HDMI and 1080i. The manual says that they should go solid after "checks" are made. They never do. I attached a composite cable to both units so I could view the setup menu on the Denon and everything seems set correctly. I checked with Sony and they say the HDMI ports on the TV are active and do not to be turned on. Anyone have an idea on what might be wrong?
gruber
I have the 2910 and this has worked fine over HDMI connected to my plasma but i cannot get a picture through my new amp. Just get the blinking like you do which i think means that the HDMI "handshake" will not estabilish.
The 2910 has been around a while and others on this forum reckon I need to get a firmware update. Also, my 2910 will not load or play a disc, it just locks up.:confused:
