Denon 2910 firmware, how can I tell?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Rob Sheep, Jun 5, 2005.
  1. Rob Sheep
    Rob Sheep
    Aug 17, 2003
    155
    16
    Worcester
    Hi Guys,
    I've been reading through the various threads below and I'd appreciate some help. I've recently bought a 2910, which was supposed to be multi-region but turns out not to be. I've contacted the dealer who is going to send me a disc with the multi-region hack on.
    However, I've noticed that there is a firmware/multi-region hack available to download (zipped), which may be what I'm looking for. Before I try it I need to check the firmware that I already have, can someone tell me where to find it and if V8 is the latest?
  2. deanym
    deanym
    May 29, 2004
    1,788
    +141
  3. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    These instructions apply to the 3910 as well.
    Remove any discs you have in the player and turn off, not standby!
    Hold the play and open/close buttons on the front panel and turn.
    Once LOADING appears on the front panel you should see Play and Pause icons, release the buttons.
    Then on the remote press Menu, 3, 2, 6, 5, Menu.
    You should see ESS and a number. the digit after the hyphen is the version.
    Just turn off the player to get out.
  4. jrosado
    jrosado
    Feb 14, 2004
    172
    Portugal
    If you do get that disc, and the version is higher than version 8, please feel free to provide us with a copy of the file :hiya: :D
    Regards,
    J. Rosado
  5. Rob Sheep
    Rob Sheep
    Aug 17, 2003
    155
    16
    Worcester
    Will do, as soon as it turns up! :thumbsup:
  6. jrosado
    jrosado
    Feb 14, 2004
    172
    Portugal
    Hi:
    No cd yet?
    Regards,
    J. Rosado
  7. Rob Sheep
    Rob Sheep
    Aug 17, 2003
    155
    16
    Worcester
    It turned up today but I need to check what is on it....
