Denon 2910 blank screen
Discussion in 'Blu-ray & DVD Players & Recorders' started by smurf, Oct 22, 2005.
  1. smurf
    smurf
    Feb 10, 2004
    33
    Gillingham
    Have had a Denon 2910 for 10 months, fantastic player.
    In the last month, whenever I play a DVD the screen will go blank for a second once or twice per DVD.
    Have run a cleaning DVD through the player.
    DVD Player HDMI connection to DVI connection on a Philips 32 LCD TV.
    Has anyone come across this before - any advise would be welcome.
    Thanks for any help
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Firmware updates. Someone has reported issues during chapter changes with the 'A' firmware.
  3. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    Not here, I'm been running 6720-A MR (MultiRegion 22/04/05) for the last 2 weeks and it has performed great.
  4. paulst10
    paulst10
    Dec 16, 2004
    12,873
    Essex
    +2,310
    i had this problem when i owned a 2910, i put it down to a hdmi problem with the player, and i ended up returning and exchanging it for a dv79.
    you could try a firmware update, ring denon for the disk but it could take up to 6 weeks for it.
  5. smurf
    smurf
    Feb 10, 2004
    33
    Gillingham
    Thanks for the advise, have sent off a note to Denon.
    :thumbsup:
  6. mcnallbe
    mcnallbe
    Hi, Did you hear anything back from Denon about this problem? I've got exactly the same issue (Multi-Region 2910 with HDMI which was fine for a couple of months, but in the last few days it's starting blanking the image - but not the sound - for about one second per hour or thereabouts), so if you've got any more information on this then I'd be keen to hear it.
    Thanks,
    Ben
