denon 2900 poor picture
Discussion in 'Blu-ray & DVD Players & Recorders' started by mark pallister, Oct 23, 2005.
  1. mark pallister
    mark pallister
    Mar 1, 2005
    88
    hi need help please
    ive just bought a samsung 32in lcd tv
    denon 2900 connected via componnent leads picture v poor
    have tried s video just the same
    even tried a different player but just the same
    tv picture is great
    any ideas
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    I can only suggest asking in the LCD forum because you have proven the DVD player is not at fault. One suggestion is to feed the LCD a non progressive picture. If you are, change it to progressive and see how it looks.
  3. mark pallister
    mark pallister
    Mar 1, 2005
    88
    thanks i tried that and it didnt seem to make any difference,
    i think i might have to buy a dvd player that upscales
  4. StuJe
    StuJe
    I assume you have set the Denon to output component, I find the component leads need to be pushed in quite hard on my 2900. The picture from the 2900 is normally excellent, the manual ain't.
  5. mark pallister
    mark pallister
    Mar 1, 2005
    88
    hi stuje
    i didnt know u had to set to output component?
    but anyway it does the same if its connected with svideo
    the fault appears to be with the tv .
    its getting returned on weds
    thanks for the reply
