Denon 2900 / Pioneer 506XDE
Discussion in 'Blu-ray & DVD Players & Recorders' started by Chris Blackwell, Oct 22, 2005.
  1. Chris Blackwell
    Chris Blackwell
    I am picking up some leads tomorrow to hook up my Denon 2900 DVD player to my new Pioneer 506XDE Plasma using RGB. I just wondered if any of you had ideas as to the best configuration for both the DVD and the Plasma.
    Many thanks!
  2. Timmy C
    Timmy C
    Oct 10, 2003
    5,702
    +592
    I'm not familiar with your plasma but the best picture you can get out of the Denon 2900 is using the prog. scan output via the component out sockets.
    If there's no spare component inpus on your plasma then I guess RGB scart would be the next best thing but it won't look as good.
    Hope this is of some help!
  3. Chris Blackwell
    Chris Blackwell
    Plugged it up and spent a while switching between Component and Video output - I must say that I can't really see much difference. Does the 2900 output progressive scan via the component outputs automatically or is there something I have missed?
  4. Timmy C
    Timmy C
    Oct 10, 2003
    5,702
    +592
    I can't remember but I think you have to change something in the onscreen menu. It will be pretty straightforward though.
