Denon 2900 :: Multi-region ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by loonatic, Dec 17, 2003.
  1. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    Can I check if my Denon 2900 ia multi-region or not somehow ?
    All my DVDs are R2 but I'd like to get Finding Nemo R1.
    Cheers, Lee
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Off the top of my head, I can't remember how to access it, but there are remote/fascia codes you can press on the player so that it'll display which firmware version you're using, it'll be shown on your TV.
    Hopefully somebody will post as to how to do this.
    If you write down what you see and post it here, somebody might be able to identify it for you as multi-region or not.
    Dimmy
  3. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    That's a good idea Dimmy.
    To access the firmware info:
    1. Power off the unit at the unit
    2. Press down and hold play and open and switch the unit back on
    3. Then using the remote pressing Menu cycles through the details.
    Mine says:
    B/E 6237M
    PANEL 6236J
    DRV 030307
    Does this mean anything to anyone ?
    Cheers, Lee
  4. filmman
    filmman
    Nov 10, 2001
    257
    2
    brighton
    +7
    hi
    a multi region one gives the following
    b/e 6237 s
    panel 0043-f
    drv 030827
    hope this helps.
