Denon 2900 - Help please
Discussion in 'Blu-ray & DVD Players & Recorders' started by kumamoto, Dec 2, 2003.
  1. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    I have a denon dvd 2900, which i have had for the last 2 month. No problems at all excellent machine.But i have a minor query, when playing back a dvd on my previous sony dvd 7700 i was able to toggle subtitles on/off using the subtitle button on the remote.
    However with the denon, this is not possible, if you want subtitles on/off, you got to bring up the dvd menu and turn the subtitles on/off.
    Is there a way round it ???
    I find it really annoying that i have to bring up the menu all the time to toggle the subtiles on/off.
    Oh, my player is multi region.
    Your input will be highly appreciated.
  2. Gizmo 76
    Gizmo 76
    Aug 17, 2003
    2,236
    116
    The Apps are Calling :-S
    +495
    It easy when you know how;)
    Press your 'subtitle' button, then use the 'up' and 'down' button's to select the subtitle track that you want then finally press the 'subtitle' button again to return to the film.
    This is how you change soundtracks and angles as well, it's an easy mistake to think you have to press the 'left' and 'right' buttons instead.
    Giz.:D
  3. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    Phew thanks gizmo, i know i should have read the manual !!
  4. mjn
    mjn
    May 24, 2001
    22,096
    Herts, England
    +9,850
    and if ya got a pronto.....you could just create new button :)
