Quantcast
Denon 2900 - film/video source?
Pacha
Please help explain to me what this means:
Whilst watching 'Superman the movie' on Friday night the players display indicates I'm watching a 'video' source with a small 'v'. The following night I watch 'Superman 2' and the display indicates that I'm watching a 'graphic' source with a small 'g'.
What does this mean? Am I set up correctly? What is the difference between 'Film' Video' and 'Graphic' sources. I realise that this is probably a 'tecchie' reply I'm looking for but please try and reply as simply as possible! :(
Cheers in advance.
P.s. If it makes any difference, the 2900 is connected by component to a Hitachi 42PD3000 plasma.
vonhosen
It is to do with recognition of source. If I remember correctly it is something along the lines of:-
Film = 3:2 pulldown taking place
Graphics = 2:2 pulldown taking place
Video = 50/60Hz interlaced
For NTSC film content you should get 'film', or 3:2 Pulldown
For PAL film content you should get 'graphics', or 2:2 Pulldown
If you're seeing the 'graphic' indicator on R2 discs then the player is recognizing that the original source of the material on the DVD was film.
Pacha
What is meant by the source being either 'film' video' or 'graphic'?
Also, could someone explain, in plain english, exactly what 3:2 and 2:2 pulldown is? Is it so do with progressive scan pictures only or does it apply to interlaced as well?
Cheers in advance!
:confused:
London Marathon 2004 : 3hr34min21sec
Similar threads
