Denon 2900 Calling all owners
Discussion in 'Blu-ray & DVD Players & Recorders' started by FCP FAN, Jul 23, 2003.
  1. FCP FAN
    FCP FAN
    Hi all!
    Has anyone have this problem when outputing a Pal Progressive Signal:
    - Theres a translucid lighter bar on the righ corner of the screen and the picture is heavily shifted to the right!:(
    - Is there any "service mode" on this player and could it help?
  2. sr78
    sr78
    Sep 26, 2002
    282
    What display are you using?
  3. FCP FAN
    FCP FAN
    Im using a panasonic tx-36pd30, but just to be shure its the tv or dvd fault (i think its the tv), im aking denon 2900 owners if they experienced the same problem.
    But if the player has a service mode, maybe i could fix the problem because the image is shifted to the right (only in progressive output) and perhaps thats the cause of the translucid bar.:confused:
  4. sr78
    sr78
    Sep 26, 2002
    282
    I thought so :)
    Better check the thread on this set in the TV section, you're not the only one...
  5. FCP FAN
    FCP FAN
    Yes, But does anyone know how to acess the service mode?:confused:
