denon 2900 and projector
Discussion in 'Blu-ray & DVD Players & Recorders' started by soulbrother, Oct 25, 2004.
  1. soulbrother
    soulbrother
    i have got a denon 2900 and i am looking to buy my first projector.I know my player does not have HDMI or DVI-D output.having read a few posts on this forum regarding PQ using these outputs ,should i still get a good quality picture using componant to a ntsc & pal prog projector like the Screenplay 4805 that i'm thinking of getting.Was thining about upgrading to 2910.
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,753
    2
    In a secret location with Jennifer Lawrence
    +9,542
    I have a 2900 connected to my old AE-100 projector and the picture quality is superb.
    For the price you can get the 2900 for I would go for it.
    Don't forget the 2910 is the replacement for the 2200. The 3910 is the replacement for the 2900.
    Greg
  3. soulbrother
    soulbrother
    hi Greg.thanks for reply,how is your player hooked up ? .I was looking at the new panny ptae 700, i think this is the new one.
  4. Greg Hook
    Greg Hook
    Nov 25, 2001
    22,753
    2
    +9,542
    Mine is hooked up via a component cable to the projector.
    I am very pleased with my picture quality, particularly as I am using a long cable with a joiner in the middle as well. Its not a brilliant quality cable either. So I suppose there is room for improvement.
    You will not be disappointed. Especially if you go for the AE-700 aswell.
    Greg
  5. eatstatic
    eatstatic
    Oct 22, 2002
    1,136
    Centre of the Universe
    +45
    soulbrother,
    Also have a 2900 connected with 10m componant cable to Z2. Picture quality is not bad at all, but then again there is always room for improvement. I suppose it depends on how picky you are.
    If you are after a good quality component cable they are also available from the avforum power buy special offers section.
    eatstatic.
