Denon 2807 No Picture through the AMP
Discussion in 'AV Receivers & Amplifiers' started by dmanyuwa, May 3, 2007.
Tags:
  1. dmanyuwa
    dmanyuwa
    Hi;
    I have just started using my 2807. I have problem with video switching through this amplified, I suspect my setup is wrong. I'm using S.Vides cable from the DVD player to the AMP and normal 1*RCA cable from the monitor out to the TV. I see no video , the only time I see the video is by pressing OSD on the remote. and the picture will come togather woth the OSD display.
    Does any one know to solve this?
    BR//
  2. Jase
    Jase
    Mar 16, 2001
    10,940
    United Kingdom
    +3,306
    Does your TV not have an S-Video or Component Input? As at the moment the Amp will be downconverting the S-Video signal.
    Make sure the Video Convert Mode is set to ON for all the Inputs for starters.
  3. dmanyuwa
    dmanyuwa
    Hi Jase;
    I thought the video convert mode was for if I'm using HDMI out. I switch all of them of because of that. I'll try switching them back on. The TV have the S.Video input, for now I have only one S.Video cable.
    I bought 2*Mission M31 bookshelf speakers pairs for the surrounds, someone told me these speakers are small for this amplifier, any advice on this one?
    thaks for your quick reply.
  4. Jase
    Jase
    Mar 16, 2001
    10,940
    United Kingdom
    +3,306
    The Mission's will be fine for surround speakers. :)
  5. dmanyuwa
    dmanyuwa
    Thanks Jase;
    Do you have any recommendation when it comes to fornt speaker, center and Subwoofer for this Amplifier. I should mention though "money is an object".
    BR//
  6. Jase
    Jase
    Mar 16, 2001
    10,940
    United Kingdom
    +3,306
    If you already have some Mission's then I'd look at matching them with some more. As for Subwoofers, I'd be looking at Velodyne or SVS to be honest.
  7. dmanyuwa
    dmanyuwa
    Unfortunately I bought the M31 abroad, Here is South Africa I have not seen anyone selling Mission speakers. I'll have to make another brand choice. I have never heard of any of the subwoofer you mentioned, they are probably not here too, I'll ask around for them.
    thanks man..
